I have a couple of MX850 remotes on which I've created macros to turn on the display and set it to the appropriate input (e.g., component 2). In order to have the display accept the input, though, the (discrete) IR command has to be sent 3-4 seconds after the display powers on.
I've used the "time delay" function to add an appropriate delay between sending the "TV on" and "TV (discrete) input" IR commands, but no matter how long I make the delay (or even if I use multiple smaller delays), the remote doesn't wait ... it just shoots out the IR commands w/o pause!
Is there perhaps some addt'l technique (or s/w bug) that I need to account for when using delays in MX macros?
