First thing's first. The subwoofers sound AMAZING... and a picture is worth a thousand words.....
Disclaimer: This was my first DIY audio venture.
And due to this - I've no doubt run into a few roadblocks... One of my drivers seem to be rattling even at moderate volumes. And I did notice quite a lot of air leaking out the side, making a slight "fart" for those times that I really push it. I can't really pin down what's causing all this rattling. But when I put my hand against the driver with little force the rattling seems to cease (for the moment). So I'm assuming the driver is loosely attached to the enclosure.
I'm planning on retrofitting my enclosures with tons of gorilla glue for the inside (for the fart) and mounting brackets for the drivers (for the rattling). Right now they're secured with some spare wood screws I had laying around. I'm also planning on painting the outside black and maybe sanding down the edges so that it looks more modest. How do you get that "truck bedliner" look and is it pretty hard?
Also... is it possible to "sand" away the edges?
