1 - 3 of 3 Posts
· Registered
It seems to be stuck on "F:H" (high?) as opposed to "F:L" (low?) where it normally sits. The High fan setting is darn loud... hence, ive got a 2x120mm fan cooler on top of it.
The unit is an Onkyo TX-SR806.
In regards to temps, the ambient temperature in the room has probably dropped 10 celcius in the last few days. We just got over a heat wave. So, ambient has gone way down... how does that work? the fan should be on less!!!
Can anyone help?
1 - 3 of 3 Posts
