Status
Not open for further replies.
1 - 3 of 3 Posts
Banned
Hello, I just hooked up my DVD player to my amp. One optical cable going straight into the back of my amp. I go to play a DVD, but all I get is two channel sound from my reciever... and if I press A.F.D Auto it goes to PRO LOGIC over an optical connection... I tried going into the DVD menu and setting the output to Dolby Digital 5.1, however my reciever just isn't pcking up that it's taking in a DD 5.1 signal... just goes straight to two channel or pro logic, HELP!!!!!!!!!!!!!!
Go into the DVD player's menu and set the digitial audio output to 'bitstream' or 'raw' or anything but 'PCM'. (The PCM setting converts everything to 2-channel digital audio.)
Sanjay
Banned
Discussion Starter · #3 ·
Hey man, thank you so much for that. You really helped me out you have no idea! I was up alllll night, I also was able to set my DVD player to 16:9 mode as well, thanks a ton!
1 - 3 of 3 Posts
Status
