Status
Not open for further replies.
1 - 2 of 2 Posts
The zoom modes on my Dish 6000 are not working anymore in HD - the * button does nothing and its stuck in partial zoom. Anyone else experience this or is it my system?
I would try unplugging the unit for 60 seconds. If that doesnt work, you might need to do a hard boot, which resets the unit and loses your preferences, etc. I forget the sequence of events you need to do for the hard boot, but I believe it is in the operating manual or a dish tech will tell you. It is a sequence of buttons that need to be entered and the system shuts down, dumps its memory and starts fresh again.
baimo
1 - 2 of 2 Posts
Status
