1 - 6 of 6 Posts
Discussion Starter #1
I'm starting to think that my dvb418 is on the way out. It seems to hang on dvd-rw discs more and more. Can someone give a recommendation on what can replace this player? I like it quite a bit because it plays almost all my divx and xvid files.
One-Man Content Creator
Price range? Connection method?
I would open up the box, blow out any dust (paying particular attention to the laser) and reseat the connectors and chips.
-Bill
Discussion Starter #3
Ah, sorry, I should have been more specific:
I want something that has HDMI and component, preferably upscaling through component
price should be 40-100
I think you can get a used Oppo 970 in that range. Check the classifieds here, as well as ebay.
Upscaling of copy-protected discs over component is getting hard to find. It's no longer allowed for reasons of Digital Rights Management. There is a utility to hack the 970 firmware to circumvent the restriction. See: http://www.avsforum.com/avs-vb/showthread.php?t=832356
-Bill
Originally Posted by kruuth /forum/post/13020226
Does it play as much as the lg does?
You mean file formats? It plays divx and xvid, sacd and dvd-a.
If you don't need upscaling of copy-protected discs over component, I would recommend the Oppo 980 which replaces the 970. There is no firmware hack for it, though. $169 new, somewhat less refurbished from Oppo. You have to call to see if they have any.
-Bill
1 - 6 of 6 Posts
