Since there is so much interest in the DLPs on this forum and so many people consult here before making purchases I thought it might be helpful to summarize my experience after 3 months of ownership of my HLN467W. I bought it off Crutchfield after having to return a 50 inch model because it wouldn't fit in my armoire
Firstly, I purchased the Digital Video calibration DVD but found that my own eyeball calibration was basically the same settings as after calibration. I have never entered the Service Menu and don't feel the need to. I'm happy with the picture quality. Very happy actually, when I first got the set my jaw was on the floor. DVDs look spectacular, HDTV look unbelievable, and SD when set up right looks good. I made some adjustments using the Users menu, specifically turning the sharpness and color down, but not much more than that.
I do so a very occasional trend towards green push on a very few DVDs that tend towards green already, but nothing noticable in daily viewing.
I have COmcast and use their 5100 HDTV box-- I had them install a signal booster and that brough up my lower SD channels to pretty good PQ. I think the SD channels are perfectly decent. Nothing like HD of course but what is. I think this tV likes a good strong SD signal so if you use cable, consider having your CC install an amplifier or at least have them measure the signal.
I have had none of the problems that others have mentioned here. I've never seen a rainbow/dithering/internal reflections etc.
NO technical problems or malfunctions at all. The remote sucks big-time, I use a Harmony universal. The built in speakers are not at all bad although I have HT speakers I only use them for films and HDTV and find the built-ins perfectly adequate for most viewing.
