http://www.adireaudio.com/ look under DIY Maelstrom.
Originally posted by craigsub I came across these enclosures on AV123 from a gent who does custom building. He is selling them for $350 plus shipping each. What would be the best driver (18 inch) to use ? The enclosure is 215 liters, or about 13 cubic feet ... with twin 6 inch ports ... Here is a link : http://forum.**********/showthread.ph...3&pagenumber=8 |
The enclosure is 215 liters, or about 13 cubic feet ... with twin 6 inch ports ... |
Originally posted by Mark Seaton My math has 215L being about 7.6 cu.ft. In any case, for an 18" woofer, that's not an overly large enclosure. You are rather limited in port length with dual 6" ports so tuning very low is out of the question unless you want to cover over one of the ports. For a room that large and more of a "fun" system, I would just target strong response to 25Hz or a little lower. Without modeling, I would say that the Avalanche 18 with a little EQ would be my first inclination. The Maelstrom gives some pretty monster output from tuning frequency up in the right size box, and will do so with less power. How about I model up your planned enclosure with some slightly more accurate software than Unibox, and we'll see just how close reality is. Any model is only as accurate as the information used, limited by the assumptions made. Those boxes are big enough for performance to stradle the Pro-HT performance realm. In other words, give the Cornwalls a bottom end to keep up with. |
Originally posted by Jack Gilvey How long are the ports? My favorite 18" is the Avalanche you mentioned, but that's a small box to port it in. Sealed, it would be stellar, with an anechoic f3 below 30Hz. Big room, though... |
Originally posted by craigsub Have an Audio control Richter Scale III crossover and eq ... it is only 1/2 octave ... but should suffice for this ... And a single port with TWO of these should be killer ... |
Originally posted by Mark Seaton ... Parts Express 1000W Amps which are on sale... |
