1 - 5 of 5 Posts
My new LG 3D tv model : 65 LW6500 which I bought 2 months before switches off & resumes power very frequently when it is connected to cable tv. But it runs without interruption when connected to HDMI & Wi fi Internet connection. On using the same cable with another tv, it works well. Please give me some solutions. Thanks.
How are you connecting it to your cable system when it does this? Direct coax into the antenna IN jack, or a cable from a box? What is the tv set plugged into? Direct grounded wall socket, or UPS system or ?
The more info you give us, the better chance of a good diagnosis...
It sounds right off like maybe a "hot ground" problem, and the tv shuts down to protect itself.
Discussion Starter · #3 ·
Thanks for your reply.
1.Now the TV is connected to the cable system on wall through a coax cable , SV-2GT splitter and another coaxial cable.
2.The tv set is plugged into Direct grounded wall socket. But the same setup works well for another TV.
1 - 5 of 5 Posts
