Hi-
I have a Premier Mounts Polaris Mag-Pro. It uses 1.5" NTP (national tapered pipe), which is good. The bad thing is it did not come with the pipe or a fixture to mount it the the ceiling.
...for a few dollars more ($68 retail) I can get their PP5, which is a 6x6 plate that is threaded for the 1.5". I would rather pull something off the shelf from the hardware store. I also need to get a very short cut of the 1.5" NTP, threaded on both sides.
Any ideas?
Any ideas?
