Status
Not open for further replies.
1 - 3 of 3 Posts
The picture has become elongated near the top and bottom of the screen and I can no longer see sports tickers, score boards etc.
Does anyone know what could the problem could be and weather its repairable.
Any advice is appreciated.
BTW - i'm in the process of buying a new big screen TV but this older set was supposed to go in the den.
Almost anything can be repaired if you want to spend the $$ and can justify the expense.
May be a deflection circuit dieing a slow death.
Banned
I agree with Ratman, I feel your primary purpose should be the den, hopefully you will buy your HDTV wide screen to view the correct OAR the way the director intended you to view IMHO.
1 - 3 of 3 Posts
Status
