Hello everyone.
I currently have an eMachines E17T4 17' monitor. It according to eMachines website gives out a maximum resolution of 1280 × 1024. I was thinking of using this monitor for gaming while I'm away from home. Would this monitor be sufficient enough to play the XBOX 360 on? I just wanted to post this question before buying the VGA cable.
E17T4 17' LCD Monitor Specifications
Viewable Area: 17 inches (diagonal)
Panel Type: LCD active matrix TFT
Resolution: 1280 × 1024 (native and maximum)
Dot Pitch: 0.264mm
Brightness: 270 cd/m²
Contrast Ratio: 600:1
Response Time: 8ms
Screen Treatment: Antiglare
Colors: 16.2 million
User Controls: Power on/off button, on screen display menu control buttons
Viewing Angles: 140° left/right, 130° up/down
Signal Inputs: Analog (VGA), 15-pin mini d-sub VGA
Ports: AC power input, Kensington security lock slot
Dot Pitch: 0.264mm
Response Time: 8ms
