1 - 20 of 35 Posts
Again: My Projector has only 1 HDMI input. Are there soundbars that will take the feeds from 3 sources and switch between them? I don't really want to buy an AV receiver and speakers. PLEASE?
Discussion Starter · #3 ·
Thanks. I just ordered a Sony HT-CT660 , which has three HDMI inputs and one output, so I sure hope it works.
However, the more I read, it sounds like the ARC HDMI output is audio only and has to link to an ARC spec'd HDMI input, which my PJ doesn't have.
Multi inputs to the SB is great, but the question is does the SB have an HDMI out that goes to the display, so that I can switch inputs on the SB and it will send the Video of the input I select to the PJ?
On closer inspection, one of the HDMI connections on the SB is labeled "TV OUT" and under that "(ARC)", so maybe it does both. It's kind of amazing how little info there is out there for this particular issue. I suppose it's because most PJ theaters don't use Sound Bars because of the long throw. This short throw option isn't used very often yet, so there's no big demand for the configuration - YET.
Discussion Starter · #4 ·
If you connect your sources to the HDMI inputs on the soundbar and then output the soundbar via HDMI to the projector (or TV), you don't have to worry about ARC. ARC is only applicable if you connect your sources to the display and then output the display to the soundbar.
Your main concern will be potentially lengthy HDMI run(s), depending upon how far away your equipment is.
  • Like
Reactions: JHouse
Discussion Starter · #6 ·
Thanks a bunch. I appreciate it. It's taken about 10 hours of research, but I'm feeling like it will work now. I'm kind of amazed how few HDMI switching soundbars there are. And even more amazing that they don't brag about it or actually explain how it works even in the manuals. And fortunately, my runs are all about 6".
Discussion Starter · #7 ·
The sandbar ( that was such a funny voice to text mistake I'm going to leave it ) showed up, and I finally got time to install it. It works. And what I mean is it works like a switching HDMI AV receiver would. It scared me at first, it was a little glitchy, I tried to set it up without my reading glasses so I avoided the manual as usual , but it works just fine.
What bothers me is that I was replacing an LG model number NB3510A. And so far I like the sound of the LG much better. The 660 has a lot of tonal adjustments, which is a blessing and a curse. But you have to be right next to that thing to see what you're doing. Then when I move back to my viewing position, it sounds substantially different. It has treble, bass and voice adjustments (in a different location) and then of course the subwoofer is separate too. So it's about like working with a rudimentary equalizer. I'm top of that it has six dedicated buttons with particular sound profiles. I have checked and your manually adjusted hard settings seem to remain the same across the six buttons, so they probably just handle the ambience phase manipulation gizmo . I like the movie setting best, and I did have to knock the sub woofer down to -3. I have the treble at plus one. It sounds boomy and hollow, like it's coming out of a box. Does anyone have any suggestions for settings? The pure stereo setting is way too thin.
Discussion Starter · #8 ·
Still tweaking. Bumped woofer up to -2. Treble +1. Voice +2. Anyone got any ideas on settings?
Part of it might be just getting used to "different" which is always a human problem, but I swear it is actually worse, and not different. Sucks for me.
But I suppose I will acclimate sooner or later, or just lay down and let the feeling go away.
Discussion Starter · #9 ·
Got out the Digital Video Essentials on Blu-Ray and listened. Subwoofer, nothing below 50 HZ, at 50, it is weaker than American coffee. 60HZ and above, is much stronger and totally acceptable. There seemed to be a big dip in the high treble range, but a peak again at 15K. Anyway, just based on what I know my shows sound like on my other (real) system, here is where I am now: Voice +1, Subwoofer -1, Base -2, Treble 0. That's it. Of course I realized that such things are room dependent. Good luck to all.
Discussion Starter · #10 ·
I forgot to mention: when I was doing the surround sound testing on the VE disc, I was stunned that the sounds actually sounded like they were coming from where they were supposed to, i.e. from the sides and rear. Kind of a miracle, or the power of suggestion, I don't know which. But the sound is spacious, without that wonky out of phase feel.
Discussion Starter · #11 ·
Last night and decided to use the old audiophile technique and listen to a lot of music I was very familiar with to tune the sound bar by ear. Result: mode: standard; voice:+4; SW: -1; bass: -1; treble: +2.
This got rid of the tunnel or coming from inside of the box sound of the system. Now I can listen to it without noticing. The music sounded very good, and everything seems acceptable. So it is decent, and I am reasonably happy. And so our saga comes to an end.
Discussion Starter · #12 ·
Not so fast. Went to my son's place and listened to his Pioneer Sound Bar (that we got him for Christmas based on the reviews, you know the one, named for some audio wizard, whatever) and it sounded GREAT. Made me feel bad. Sound wasn't nearly as clear on mine, especially the vocals. Also, I got jealous of his bluetoothing Spotify. So I came home and set up my phone to play my Amazon library via bluetooth, which allowed me to listen to a LOT more variety of music I know very well and recalibrate. It worked very well. I listened to about 40 songs (parts of them) and set it as I went, eliminating too much sizzle, too much boom, big dip in the midrange, etc. I recognized how much difference the room makes, but mine is large, stone floor, but lots of stuffed furniture and rugs and drapes and a totally irregular shape. The biggest idiosyncrasy is that the sub is in a corner/cubby which probably amplifies the heck out of it. So your sub level will certainly vary. Here's where I ended up: Voice +4; SW -5; bass -1; treble -1. It now sounds really good. And the voices on video content is now extremely clear and natural. There must be a huge dip in the midrange as these things come from the factory.
I'm looking for something similar, so I thought to ask here.
I want a soundbar system with at least 2.0 that has ideally 3 HDMI inputs and 1 HDMI output or at least 1 HDMI input and 1 HDMI output (I would have to add a splitter).
I would be connecting my HTPC, my PS4 and my cable decoder, so I need the system to be able to pass 3D signals, as my HTPC and the PS4 have 3D capabilities, which I believe means HDMI 1.4.
Ideally between $200 and $300.
So far, I have:
  • Samsung HW-F450
  • Sony HTCT550W
  • Samsung HW-E450
  • Sony HT-CT660
Some recommendations to start with?
Originally Posted by JHouse  /t/1512582/my-projector-has-only-1-...sources-and-switch-between-them#post_24233200
So, how do you like it so far?
Discussion Starter · #15 ·
Keep reading this thread. I describe it in detail. A lot happier now, but the Pioneer still seems to sound better.
Originally Posted by JHouse  /t/1512582/my-projector-has-only-1-...sources-and-switch-between-them#post_24495289
Does the Pioneer has 3 hdmi inputs?
Discussion Starter · #17 ·
Nope. AFAIK The 660 is the highest rated, reasonably priced HDMI switching sound bar. Though my research wasn't exhaustive.
Originally Posted by JHouse  /t/1512582/my-projector-has-only-1-...sources-and-switch-between-them#post_24495325
I'm currently looking and so far I have:
Samsung HW-F450
Sony HTCT550W
Samsung HW-E450
Sony HT-CT660
Did you check any of those, besides the 660?
Discussion Starter · #19 ·
Nope, so let us know what you find out.
Originally Posted by JHouse  /t/1512582/my-projector-has-only-1-...sources-and-switch-between-them#post_24495448
Well, I-m actually based outside of US, so I have to import whatever I choose. This is why I ask here.
1 - 20 of 35 Posts
