1 - 1 of 1 Posts
how should i clean the vents on my samsung 40inch 630, i just moved it into a new room and noticed it had tons of dust by the vents and probably inside it as well.
is there moving fans in a 630, and would it be safe to vacuum the dust out of the vents, if not what should i use to clean the dust.
also when i moved my i brought it outside and it was in direct sunlight, since the 630 has a less glossy screen than the 650, should it have made the screen appear cloudy and also should it have blurred my reflection while outside in direct sunlight. just making sure my screen is not messed up
1 - 1 of 1 Posts
