I have a dual LNB dish with both lines in use right now, so I bought an RCA 4 way multiswitch. Since my receiver is coming tomorrow I thought I would get a jump on things and put up the multiswitch tonight.
When I disconnected the existing set up and put the two feeds down from the dish into the switch and hooked the two existing feeds to the receivers in port 1 and 2 no signal.
Did I do something wrong, does it need to have all three out feeds in it to work. I check all the connections and still no luck.
Any thoughts or advice guys?
