Status
Not open for further replies.
1 - 6 of 6 Posts
I get a "Not connected MyHD Remote Controller Receiver . Check your serial port." error whenever I launch the IR receiver utility.
I tried attaching the receiver to COM1 and COM2, neither appears to work.
This is a P4 1.6 ghz, on an ASUS P4T, running XP.
As far as I can tell, the ports aren't being used by anything else.
Has anyone else seen any problems like this?
Have you checked to see if the myIRC program is running? On my installation that is required for the remote to function.
Joel
1 - 6 of 6 Posts
Status
