I installed the MDP-120 card that I got from digital connections yesterday. The problem is that it will not tune in any channels, and it will not go into full screen mode.
PC Setup:
OS :WinXP Pro
CPU
4 1.6A
MB :Asus P4B266
Video :ATI AIW 7500
** update **
on IRQ 20 MyHD MDP-120 by itself
I have tired it in each open PCI slot, the last one I tried has the card
with an IRQ that is not used by anything else
First problem is that the drivers never installed per the instructions. When I get to the install page where you select "Search for the best driver in these locations" and check "include this location in the search", I browse to the CD location which is for me "D:\\Driver\\win_xp". When I click NEXT I do not get XP warning for compatibility, instead it always says "The hardware was not installed because the wizard cannot find the necessary software".
The only way that I could install the driver was to select "Don't seach, I will choose the driver to install" instead of "Search for best driver..." like above. Then from there select "Macro Image Technology, Inc." and click the HAVE DISK button and select the SAME CD location listed above. Then it will install fine. Following that I installed the application without any problems.
Now that everything seems ok I start the application and the overlay comes up and says not signal. I am using the Silver Sensor antenna from Zenith. I have checked antennaweb and found the direction to point but nothing. I have also connected my Time Warner cable to the ANT2 connection and I am unable to tune in anything from that either. The other problem is that the full screen mode never works. I have tried both the single monitor setup, and the dual monitor setup. When I am using the dual monitor setup I get NOTHING on the monitor connected to the MyHD VGA output.
The only time that I have seen anything on the overlay was when I connected my VCR to the composite input and selected that input on the MyHD application. The overlay displayed the video, but full screen still will not work. The remote has worked fine and I have no problems with that.
I bought this so that I could watch the Superbowl in HD on my projector, did I get a lemon? If so I don't even want it anymore. Now I have just three days before the game and there is no way to get one that works in time. Very frustrated! Is there anything that could cause this that can be fixed or configured?
I would appreciate any help with this,
Mike
PC Setup:
OS :WinXP Pro
CPU
MB :Asus P4B266
Video :ATI AIW 7500
** update **
Mike
