Originally Posted by netman /forum/post/0
Or you could turn off "virtual channel" mode (from the Channel List menu) which sound like it is set.
It is. It is the only way that auto scan will map in the virtual channels and it sounds like, all of the DTV sub channels as well.
Also, why are you not using the remote?
How does that help getting to a sub channel. I tried it with the remote by entering the channel number of the station and then hitting the sub-ch button, again, nothing.
OK, I just tried it again. This time I turned off virtual channel mode. Damn, the sub channel button now works. OK, that helps explain the poor english in the manual, specifically the piece that describes the remote control SUB-CH button. But, the configuration box that has the on-screen sub-channel button, there is no note that says it doesn't work in virtual channel mode.
I prefer the virtual channel listings, so I'll have to get at the sub channels by channel changing through them, just like I do now with the two STBs.
In any event, thanks for clearing up how that all works.
