Status
Not open for further replies.
1 - 4 of 4 Posts
I have been looking at the girder stuff and it seems like what I want to do I should be able to do (buit I can't find the plugins)
1. I have the IR sensor for the MYHD remote
2. MyHD remote
So the MyHD can learn other remotes (sony) also - fine - easy
But Can I use Girder (we a pre-built plugin) to control WinDVD and Zoomplayer?
If so where are the plugins?
DO I need to write this myself??
SOrry - I am really confused on this (yes, I have been to the FAQ :)
Yes,
you can, but you will have to use Girder to control all three. Zoomplayer gives you the ability to generate a gml file, I am not sure about windvd, but I believe there are gml files available for myhd. I believe Bob Sorel is making a new one for the latest version of myHD.
Then you just train girder and the myIRC apps to use the remotes of your choice to control the apps that you want.
I have used the default UIR/IRMan plugin that comes with Girder to recognize the myHD receiver. Didn't have to do anything special.
There is a lot of info on the forum about things like this. Use the search.
Anand
Discussion Starter · #4 ·
Ok, thanks for the tips. WIll start to figure this out :)
WHat remote did you guys buy? I think the MyHD has enough buttons for just about everything.
1 - 4 of 4 Posts
Status
