Status
Not open for further replies.
1 - 9 of 9 Posts
For the folks having a problem where the use of other device remotes causes MyIRC to fast forward or rewind during file playback here is a replacement MyIRC.exe file that fixed the problem for me.
www.nabs.net/cwatson53/MyIRC.zip
To install the new MyIRC file
1) Right click on the MyIRC icon in the system tray and select "Exit MyIRC"
2) Copy the new MyIRC.exe file into the MyHD folder in C:/Program Files
3) Reboot the computer
Cliff, the update solved my problem between MyIRC and my Yamaha RXV-2200 receiver... Thanks for the help on this... Now I can use my Pronto remote again and put my touchpad PC back where it belongs.
Thanks Cliff.
This solved my problem with my Yammy DSP-A1 volume control causing a FF in MYHD.
Also, please say thanks to MIT assuming they are not on holiday - again:)
Joe
Cliff,
Terrific! Thanks so much. This solved the remote control problem for me. Previously, the volume up/down on my Toshiba TV caused erroneous FF and REW events on MyHD. This new myirc.exe file solved the problem!
Thanks for the great service!
Brett
1 - 9 of 9 Posts
Status
