Status
Not open for further replies.
1 - 2 of 2 Posts
Was considering an NAD T752 receiver, but a little hesitant because of some complaints regarding the fan being too loud / on alot. Sent an email to the company - recieved following reply (which I got permission to quote).
Thought this might be of some interest to others who had similar concerns:
> Dear Dr. Drake,
> I am sorry someone hasn't replied more promptly to your question. Our
> Webmaster, Mr. John Milder, passed away very suddenly in November, and we
> are all scrambling to fill in until we can find sombody to try to fill his
> very large shoes.
> Regarding the fan noise issue for the T752, there were some early
production
> units with improperly adjusted fan circuits that caused the fan to run at
> full speed much of the time. This is not typical behavior. In fact we
were
> quite shocked when we started receiving these comments, because most of us
> at NAD had never heard the fan operate EVER on our beta test units. Only
> the Lab engineers, when doing high power measurements and reliability
> testing, had the fan running. With normal program material it is very
> difficult to get the fan to run (4 Ohm speakers with compressed disco
music
> playing at +100 dB SPL it takes about 10 - 15 minutes before the fan kicks
> in, and then the fan runs for less than 1 minute when the music is turned
> down). We now know that some units were shipped that would start running
> the fan after about 30 minutes even with no signal playing - clearly not
the
> way we designed it, but not something that showed up in our normal
> production QC checks.
> Why do we use a fan? Because we rate our power honestly with all channels
> driven, full bandwidth, and we allow 4 Ohm speakers to be used with most
> models. With a T752, this means that over 400 watts must be dissipated in
> the output stage under certain operating conditions. To do this without a
> fan would require a unit about 3 times the physical size, and obviously
far
> more expensive, with no real consumer benefit, since 99% of our customers
> would never achieve this "worse case" condition.
> The T742 does not use a fan. It is rated at 50 watts per channel, all
> channels driven simultaneously 20Hz-20kHz at 8 Ohms. We do not recommend
4
> Ohm speakers with this model, because there is no fan, although like all
NAD
> amplifiers this model is fully stable at even 2 Ohms loading.
> Again, our apology for not answering more promptly, and I hope this reply
is
> helpful in making an informed purchase decision.
> Best regards,
> Greg Stidsen
> NAD Electronics
1 - 2 of 2 Posts
Status
