1 - 15 of 15 Posts
Discussion Starter #1
Is it me or does some of the live coverage look highly compressed or is it a problem on my end?
EDIT: It only look's to be compressed on NBC sport's network MSNBC looks fine. weird
It could be. Maybe try the "motion flow" or whatever it is called on your HDTV if it is jerkey; otherwise if it is macroblocking, IDK how to fix it. I was watching some on NBC Sports last night and it looked fine using my HDHR Prime..
Discussion Starter #4
source is charter, it's just weird both channel's are part of the same network yet there's a noticeable difference in PQ between both of the channel's.
I'm on Charter too. Suppose I'll have to take a look at the MSNBC feed. I was watching soccer a bit last night too and it looked great to me.
Discussion Starter #6
Ok I think I figured it out I just did a comparison between my tv and projector both have the same problem. Everything on MSNBC is fine NBC sports network picture is fine with still or slow moving close up shots but distance shots are a little fuzzy if that makes sense and there's a ton of macro blocking on fast moving close up shots.Everything was fine during the NHL playoff's on NBC sports network.So I think I can rule out a problem on my end.
I was under the impression that the feeds out of the UK are at 50 fps at 1080i. Wouldn't that cause a degradation in PQ compared to the 60 fps you'd get out a US broadcast?
I will say the NBC soccer and basketball olympic channels do look pretty bad compared to the other NBC feeds.
I'm thinking that NBC has their own feed coming from over there. Because the UK stream is also H264. So I don't think it is being transcoded on the fly.
Originally Posted by whiteboy714  /t/1421958/nbcs-olympic-picture-quality#post_22258353
But it does look like both are about 15mbps.
True but maybe the OP is thinking it is a CableCARD tuner issue?
Originally Posted by PacketHauler  /t/1421958/nbcs-olympic-picture-quality#post_22258275
The NBC Sports soccer feeds this past weekend were terrible on Dish.
1 - 15 of 15 Posts
