I'm considering getting two SVS PB10-NSD or PB12-NSD speakers (likely in combination with the SBS-01 system) and using them as end-tables, and had a few questions. My room is 20' x 15' x 8'.
1) Can I realistically use these as end-tables? Will I be able to put a drinking glass or a lamp on these while they're "doing their thing" or will my glass end up shaking a lot?
2) One of the SVS reps recommended that I position them so that the speaker faced out toward the room (same direction I'd be facing when I was sitting on the couch). On the one hand, it would seem to me that facing the speaker toward the couch should allow me to feel the bass more, but the dimensions of the sub are such that positioning the subs this way would result in them taking up too much floor space, so I was actually glad to hear the SVS rep tell me this. But I just wanted to run this past the folks here in case anyone has had personal experience with near-field placement near a couch and had an opinion that differed from theirs.
3) As for the 10" vs the 12" models, I'm not sure which way to go. Two PB12-NSD's should reach slightly lower frequency ranges, would make for a better end-table height-wise (though probably a bit oversized in depth and width), and would provide more bass power overall. But I'm worried that it might be overkill for me as my wife always complains about the volume of my movie playing as it is, so I'm worried that I'd end up with more speaker power than I'd ever take advantage of. Thoughts?
Scott
Scott
