I have a 6pg+ that has a strange problem with the electrical focus.
With all convergence settings on the projector set to 0, the blue crt
seemes to be bowed to the left and down a bit.
When the blue electrical center focus is increased above 0, the
blue crt will slowly become more rectangular (somewhere around +45%).
The strange thing is... adjusting the green electrical focus will also cause
the blue crt to shift in the same way. The red focus seems normal.
Is this a problem with the def or focus board? or could it be a problem
with a coil on the blue crt? I believe all the connectors are attached correctly.
See bad attachment (ignore the gaps in the blue).
