NEC Experts....does a 9200 have any issue with tri-level sync??
I have a Scientific Atlanta 3100 HD box and it's going through a ctca2 clone transcoder and the image is less than stellar. If I use sync on green it's probably even worse. The problems seem to be horrendous color in the low end, no detail in the low end...basically the pic is just not very good.
I previously owned an Infocus5700 DLP and that thing was so much better at HD than this CRT that it's not even funny. Sure dvd playback was inferior on the digital but high def was in a different league. I fully expected to see just as good quality high def through the crt, but that's not the case.
Bottom line question, is this a tri-level sync issue? Is there anything I can do to detemine if it is? Would an Extron sync converter get rid of the sync on the R and B channel?
Ben
Ben
