Status
Not open for further replies.
1 - 4 of 4 Posts
After reading your forums and doing a fair amount of research I decided to dump my NEC LT80 DLP and I purchased a NEC 9PG CRT Projector from a local auction. The thing is mint with no CRT burn. I would like to know how many hours is on it though. It is asking for a four digit pass code to access the adjustments menu. I have tried a few of the obvious ones and read the manual on the pass code, but it doesn't tell you how to reset the pass code if it is forgot. Someone told me the Tech pass code is 3135 which I tried and it didn't work. If anyone knows anything about it please let me know. thanks
Kevin Clements
2 5 8 0, straight down the keypad.
Can anyone say how to reset the passcode? I am waiting on delivery of an XG135 and hope there is none set but what can I do if it has one from the previous owner.
For XG's use 3151, when you sign on with the service passcode on any of the NEC's you can delete the old passcodes.
1 - 4 of 4 Posts
Status
