Status
Not open for further replies.
1 - 12 of 12 Posts
Premium Member
I have a customer with a Runco 900 or 900a.
I believe this is a 6pg or 6pg+
It randomly snaps out of convergence but always corrects itself but this time around it has stayed misconverged and not returned to normal.
The focus is also way out. When pulling up the cross hair the red is triple the size it should be as is the blue. Green is fine. When lining up the cross hair the r/b are now bleeding beyond the green.
What could this be?
Thanks for your help.
Change all of the STK chips on the F and C boards. I can swap you boards if you want, I have stock, or I can supply the chips to you, either way.
No charge of course, let's hear it for our hosts, rah rah!
Curt
Alan, unless you are really really really proficient with a desoldering tool, you really want to swap out the boards through Curt, not replace the modules.
I did the module replacement sucessfully on my f-drive, but it is a bear....
Vern
Yep, what they said. Common problem after a few years. Easy fix.
Allen, If you can solder, it's not that hard. There may also be a few bad connections to re-solder at the same time.
Curt, how about a free replacement green tube for a PGplus? You're such a swell guy..... I'll just PM you the mailing address.
Marc
When the rest of youse guys' websites give me as much business as this one has, then you get freebies too.
Today's special for every other forum member is a free mind meld with your projector. Hold your computer monitor close to the projector and chant:
ooommmmmmmmmmmmmm.
There, it's guaranteed to run problem free for the next 10 minutes.
Cheers!
Curt
Ya know, I wonder if Uri Geller ever perfected curing burnt phosphors.
Curt
Do you do anything else during the day other than round up business for Curt WanMan ? :)
I know how you network types are.... the ones in my office just sit around and make my life miserable. :)
Banned
I am not a LAN Nazi! I wait for sudden disaster (which comes and goes) to strike and entertain myself fixing the problems. Besides, my laboring for Curt may need to change since no kick-back checks have arrived yet.
Do I get no credit? Your projector has been working great for a long time. It's one of several sets out there that I chant a mantra for every hour of every day..;)
Curt
1 - 12 of 12 Posts
Status
