Status
Not open for further replies.
1 - 3 of 3 Posts
From the pictures of the NEC HT1000 brochure the ceiling mount has a provision for a tube that is attached to the ceiling. How is the tube attached to the ceiling? Does the tube come with the ceiling mount or is it another thing to purchase? What type of ceiling mount / brackets do you use?
Thank you.
watch out for the nec's offset. my projector is mounted 3/4" from the ceiling and with a 100" screen it puts the top of the projected image at 14- 16" from ceiling hieght of eight feet. Only use the post if you have very high ceilings.
I believe it fixes to a flange which is then screwed to the ceiling.
A few of us here have made our own - in my case using one of a pair of speaker wall mounting brackets and mdf (pics on my website).
Some are quite ingenious (Tors' for instance), and oner included strapping the pj straight to the ceiling!
Gary.
1 - 3 of 3 Posts
Status
