1 - 20 of 51 Posts
Might as well start a new thread specifically for the upcoming NEC L50W, for news, reviews, opinions and of course hype!
Specification
Native Resolution 1280 x 800 (WXGA)
Brightness 500 ANSI Lumen
Contrast Ratio 2500:1
Lamp LED Light Source (no lamp required)
Lens F= 1.5, f= 13.92 mm
Projection Factor 1.4 : 1
Projection Angle [°] 13.8
Projection Distance [m] 0.52 – 3
Screen Size (diagonal) [cm] Minimum: 43.2 / 17" ; Maximum: 254 / 100"
Focus Adjustment Manual
Supported Resolutions 1920 x 1080 (HDTV / 1086 i); 1680 x 1050 (WSXGA+); 1440 x 900
(WXGA); 1400 x 1050 (SXGA+); 1366 x 768 (WSXGA+); 1280 x 1024
(SXGA); 1280 x 960 (QVGA); 1280 x 800 (WXGA); 1280 x 768
(WXGA); 1280 x 720 (720 p); 1152 x 870 (MAC); 1152 x 864 (SXGA);
1024 x 768 (XGA); 800 x 600 (SVGA); 720 x 576 (576 i/p); 720 x 480
(480 i/p); 640 x 480 (VGA)
Frequency Horizontal: 30 – 100 kHz; Vertical: 50 – 85 Hz
CONNECTIVITY
RGB (analog) Input: 1 x Mini D-sub 15-pin, compatible to component (YPbPr)
HDMI® Input: 1 x HDMI® (Deep Color, Lip sync)
Video Input: 1 x RCA
Audio Input: 1 x 3.5 mm Stereo Mini Jack
USB 1 x Type A (USB 2.0 high speed); 1 x Type B
Video Signals PAL; PAL60; NTSC; SECAM; NTSC 4.43; PAL-N; PAL-M
SD Card yes
REMOTE CONTROL
Remote Control Audio Control; Auto Adjust; Digital Zoom; Source Select
ELECTRICAL
Power Supply 100-240 V AC; 50 - 60 Hz
Power Consumption [W] 105 Normal Mode; 70 Eco Mode; 0.5 Stand-by Mode
MECHANICAL
Dimensions (W x H x D) [mm] 226 x 43 x 174 (without lens and feet)
Weight [kg] 1.2
Fan Noise [dB (A)] 32 / 38 (Eco / Normal)
ERGONOMICS
Safety and Ergonomics CE; ErP; TÜV GS; RoHS
Speakers [W] 1 x 2 (mono)
Psychic predictions:
• The resolution accepted as "native" by the projector is 1280x800.
• It's just as loud as the Acer and Optoma (looking at the case the cooling setup appears to be identical.)
• It has the same focus and chromatic abberation "issues" (very subjective).
• The built-in player has the same issue as all the others.
• Your wallet will be significantly lighter.
It is however very sexy looking, unlike my Acer which looks like a chinese knockoff of an Apple product. It also has the least amount of inputs/outputs. Maybe they should list that under ergonomics. No pesky ports sticking out!
Discussion Starter · #3 ·
Well if it's more sharper than the others, and no start up focus issues and the rest the same... then I'll probably be sold.
when you believe zol.com the hottest fan exhaust should be nowhere near the (plastic) lens, so no focus issues.
in my opinion the biggest issue till now with the nex gen led pjs is the ca. for me its fine if the picture is a little bit softer if there are no artifacts or in this case colored edges.
these are all built on the same "platform" -same lens ,led, powersupply ,fans,dlp chip and same layout and I assume its all mounted on a main board and droped in different cases with I/O boards and switch boards being plugged in the main board.
Originally Posted by PoisonWolf /forum/post/21043586
Anyone know the tentative price for the NEC??
in germany it is listed at 599 which is about 810$.
because of the focus slide i am wondering if the range of it is big enough to focus pictures which go bigger than the 100" (max diagonal from specs).
Sounds like a terribly loud and expensive projector:
http://www.projectorcentral.com/NEC-L50W.htm
Now what's the real difference between this new NEC and the existing Casio laser LEDs?
http://www.projectorcentral.com/Casio-XJ-A140.htm
casios hybrid is not able to show blue colors. its all like purple. it has a color wheel which leads to rbe and early failure because of the mechanical part
You will get the RBE on the NEC too.
So after all this negative aspects, and it being only 500 lumen... what is the main positive aspect for this projector? I'm sincerely asking this question by the way. Am curious as what is the strength of this unit?
besides the negative aspects of the 500 lumen range theres one very positive:
everyone is reporting very little to none rbe. the leds seem to cycle fast enough
on casios its still very noticable because of the wheel for green cycling relatively slow
annoying RBE effect so few its a non issue.
depends on which one(there are 23 versions)but out of the top I would say thousands of lumens, better lenses, power zoom on some, a .7 dlp 1280x800 on some(they have .6 1024x768 also) a 3 year waranty.Most like the led ml500 but my casio xja240 gets the most attention.
I'm just speculating, but I would think it would be similar to the Acer. You can't just keep turning the lens on that either. It has a limited range. The Acer does go past 100" though, even though the manual lists the projection size as 30-80" (which seems reasonable to me brightness wise.) I don't have the space to go past 110", so I don't know just how far.
I have never seen a Casio so I don't know how bad it is. There is definitely a RBE on the Acer though. I didn't notice it initially, but I can see it if I make fast eye movements and it's dark. Not an issue for me, but it obviously doesn't switch fast enough to eliminate it completely. I don't know what it would be like for someone who was very sensitive to it.
2500:1 contrast ratio
Video files supported include MJPEG (AVI), MPEG2, H.264 (AVI, MOV, MP4, 3GP) and WMV
I like that I could take my SDHC card from my camera and stick it in the projector for a quick slideshow of the days shots and video.
Built-in wall color correction presets provide for adaptive color tone correction to display properly on non-white surfaces
Carbon savings meter calculates the positive effects of operating the projector in ECO Mode, which is encouraged by an optional message at startup
Sounds cool
10-step magnification with location control allows you to zoom in on key information
Would this be for powerpoint type presentations?
2-year limited parts and labor warranty, education customers receive an additional year on their warranty, and Star Student customers receive an additional 2 years
Tells me they expect it to last at least 2 years
Also wondering what Advanced AccuBlend and AutoSense are?
(they were listed under additional features for this projector on one site)
I looked up the answer for you
Advanced AccuBlend technology automatically resolves the difference in resolution between source data and the images you project. With Advanced AccuBlend, you can project in SVGA using SXGA data, for example. The same technology makes zoom-in views smooth. Also, special algorithms protect text and thin horizontal lines during compression. Gain power, sacrifice nothing.
NEC's exclusive AutoSense
Technology automatically synchronizes and adjusts the protector to
optimize incoming computer and video signals, eliminating timeconsuming
manual adjustments.
Is the release date still sometime in October?
It'd be a plus if any of the available NEC software works with the L50W.
http://www.nec-display.com/dl/en/pj_...ip.html#ht1100
Desktop Control Utility 1.0"
Is software that operates the desktop screen of a personal computer at a remote location from the projector by using a network.
A commercially available USB mouse is connected to the projector to operate the personal computer.
http://www.youtube.com/watch?v=sDugS9m3DUE&NR=1
eBeam Interactive
Like a USB mouse, using the electronic pen enables you to operate the personal computer.
Furthermore, assuming that the projector screen as a white board, any characters and figures can be drawn on it using the electronic pen.
Virtual Remote Tool
This is software for operating a projector connected by LAN (wired or wireless), serial connections (RS-232C) or computer connection cable (signal cable) from the computer.
The following projector operations are possible from the personal computer:
Power on / off
Input signal switching
Muting (temporarily disabling audio / video)
Freezing (locking the projected image)
Operating Remote Control
The logo image transmission
http://www.youtube.com/watch?v=1OWws...feature=relmfu
1 - 20 of 51 Posts
