Status
Not open for further replies.
1 - 3 of 3 Posts
Hello everbody,
can every LT 150 user give they currently settings for contrast and brighness, especially for they use with HTPC.
Thank you very much.
this is really a great Forum.
Richard
Richard,
In my opinion the best solution is for you to buy a copy of Avia and do the brightness and contrast calibrations yourself.
Black level and white level will change depending on a combination of factors: your video source, the age of your bulb, your screen material, etc.
Avia is easy and fun to use. Others might recommend Video Essentials; I'm not familiar with that DVD, though.
As a starting point the projector defaults aren't far off from my LT150 settings.
-- billy
I'm currently using the stock settings but will be Avia-izing it after I get a screen. Most of the reports I've seen here indicate that the stock settings are close to right on.
Tom L.
my-wannabe-home-theater
1 - 3 of 3 Posts
Status
