I got this after i did a full system board reset,i didn`t have it before the system reset,you can see the problem in the drawing i made,I`m sure the solution is somewhere in the factory setup adjustments but the big question is...where ??
I get it in all RGB+HV resolutions and also in the composite input,it disappears only if i turn off the AKB system.
Needs an expert help... ! !
Thank you,
Yuval.
Thank you,
Yuval.
