Status
Not open for further replies.
1 - 4 of 4 Posts
I have the RC 6051 remote for my Nec Pg 9200 which is the correct remote.
When I am using the point function the left arrow moves things right , and right moves left. ( up and down is fine )
Does anyone know if this is normal or could I possibly have something connected backwards.
( I was previously using a different remote with the same problem )
Jim
Your scan plugs are reversed...Check the illustration under the top cover for correct orientation.
Actually, to clarify, the plugs on the C-drive are reversed. The last 3 towards the rear of the projector if I recall correctly. Flip those and try again.
Marc
1 - 4 of 4 Posts
Status
