I'm looking for a LCD HDTV which will allow me to hook up my Comcast basic cable (i.e. no STB) for analog and QAM channels, as well as an antenna for OTA channels. Mitsubishi is the only brand I've seen so far that has 2 RF inputs and is designed to cover my needs. Other brands like Sony and Samsung only have one RF input so you can only have either cable or OTA, but not both. Sony's manual recommends using a RF switch if you need both. However this is a crude solution in that you would need to go to the back of the set and flip the switch whenever you wanted to change RF inputs. Are there more solutions than Mitsubishi for my needs?
