I'm looking for 8 ohm speakers for my setup. I have a Thorens TD 126 MKii and Marantz 2230 on the way and need a pair of bookshelf/compact speakers. Looking for bookshelf that are less than 13 inches, but can deal with 15 inch. Must be front ported. 8 or 6 Ohm speakers with sensitivity ratings of 90 db or higher is preferred.
Not completely sure about the budget, but lets say a couple hundred give or take. I am not looking for long-term speaker investment, just something that puts out good sound for the short-term. Vintage or modern is fine. Prefer to buy used, but will buy new as well. So if you want to recommend something is often found on the used market, definitely do it!
I enjoy large soundstage, sparkly but smooth treble and lively mids with great vocals. Bass impact just needs to be natural and present. Mostly listen to classic rock, grunge, and classical
I do have a Definitive Technology ProSub 800 that I may use.
