Status
Not open for further replies.
1 - 16 of 16 Posts
· Registered
I live in Kirkland, which is east of Seattle. I am on a small hill, and with my Silver Sensor I get adequate reception of most of the local digital stations. I have two that are kind of marginal though... I get dropouts and freezes sometimes, and if the Silver Sensor gets looked at funny the reception really gets bad. To watch the Enterprise premiere in HD I had to sit very still on the couch, and I finessed the antenna by putting a drink coaster under one edge of the base. :) I hate monkeying with the antenna!
One of these marginal stations (UPN) is going to up its power soon, but our Fox affiliate will probably remain borderline. I'd like to get all my stations locked in really good, so I think I need some more gain.
Luckily the TV is on an exterior wall--and just on the other side is my second story deck, which faces the right direction, and my elevation is good. Because of this I could install an outdoor antenna relatively easily. All my transmitters are within about a 30-35 deg arc, which is also good.
The way I see it I have a few options... I would appreciate your thoughts.
1. Move the SS outside. It's not really made for it, but others have reported getting away with it. How much would this help? I'd just be getting rid of one wall -- it isn't looking through my whole house right now so it is probably already working pretty well.
2. Get a better antenna like the Square Shooter and hide it behind the TV. But the SqSh is expensive.
3. Get a better inexpensive antenna like the CM 4221 and put it outside.
4. Get a preamp for the Silver Sensor.
I'm not really sure which way to go next... Cheap and easy are obviously nice, but mounting a better antenna outside is not a huge job with the way my house is laid out. I could bolt a CM antenna to my deck railing or chiminey easily enough... but I haven't been able to find gain patterns for them so I am not even sure if they are what I need.
[Edit: Found the gain info! http://www.hdtvprimer.com/ANTENNAS/comparing.html ]
· Registered
Agreed. Though actually, on those gain charts, I like the Winegard 4-bay ... much flatter across the UHF spectrum. Though it costs like twice as much. The 4221/3021 has to be one of the best values in antennas out there ....
· Registered
You could but that probably wouldn't help with dropouts and freezes. Remember this is a digital signal. If there are dropouts, it's because not all of the digital signal is being received, not that it isn't strong enough. So an antenna with more metal to gather more signal is likely to give him those two problem stations more than making a crummy signal louder.
Does that make sense?
· Registered
Mike you might get some better responses if you locate the SF/SJ thread in the Local Reception forum.
Most of us wouldn't know the area enough to make a good recommendation.
I know you have some hills and mountains out there, that can seriously affect reception.
· Registered
I ordered a 4221 from Solid Signal this morning, $32.44 shipped. It will be going in a second story attic. I'm about 10-13 miles from the towers (roughly 10 degree spread) and the terrain in SE Michigan is flat. I will report my results once I get my 34XS955.
· Registered
Try a 10db amp with power injector from Radio Shack.
I have a SS, have a low power station 9 miles away. Without the amp, no signal at all, with the amp, 65% and no dropouts. If it doesn't work, take it back.
The 4221 is the next step, great antenna from what I've read.
1 - 16 of 16 Posts
Status
