Need a custom screen built 96" wide 54" tall
353 Views 1 Reply 2 Participants Last post by  xmenxmenxmen
Where can I get a custom screen built with some sort of fabric stretched on to it without having to build one myself? Does anyone know if a website that I can go to where they may be able to make me a screen? If not does anyone have a suggestion for building a screen like this? I have a screen with budget blackout material on one piece of 1x2 wood hanging from hooks on the floor joists. Does anyone know of better material to use. Image is OK but would like to know if there is something better out there.
I would like to spend between $100-$200. I know the blackout material is only about a 1:1 gain but just curious if there is something better for the type of projector I have. I would also be up to purchasing a screen manual pull down, just curious what might be the best pull down screen in my price range as well.
I have an InFocus ScreenPlay 4805 if anyone has any suggestions for screens for this type of projector please let me know.
You can also email me at [email protected]
Status
Not open for further replies.
1 - 2 of 2 Posts
I would still recommend building it yourself. blackout is still go for you need. Consider painting to one of the color recommended by the forum if you desire better.
Read the FAQ for suggestion.
1 - 2 of 2 Posts
Status
