So, I am a newb to home audio, so I apologize in advance for my lack of knowledge.
Please see the attached image of what my room will look like when I get it finished. The wires will be run through the walls, but I am not sure 7.1 is ideal for my room. I am trying to spend 6-700$ for the audio system, and then I will get a blu-ray player separate. I have had my mind on the Onkyo HTS9400, but I would rather not have that big of side speakers due to the situation of my basement. I am thinking a 5.1 would be better suited to my room than a 7.1. So, to pick smaller side speakers, I was looking at the Onkyo HTS8409, but I still have the 7.1 vs. 5.1 issue. So, my questions are:
With this room configuration, would you do a 5.1 or 7.1 system?
If 5.1, would you still do the HTS8409 or some other system?
If other system, what would you assemble component wise in my price range with smaller side speakers, yet large enough speakers for the size of the room?
Are some of the systems with all small speakers too small for my room?
Mike
Basement.bmp 2965k .bmp file
Mike
