Would someone kindly take a look at my error logs below. I am trying to put the 30XX image on a new Samsung HDD by imaging MikeyBoys file.
I believe the 1st error was due to pointing to the zip folder instead of the "showstopper&replay30xximage.img file" .
The second may have pointed to the wrong file again, it looks like it pointed to rtvpatch.img. Is this the correct file for "restore target drive"?
After the second try I the tried to patch the target drive and got the message that said PROCEED: "TARGET DRIVE DOES NOT SEEM TO BE A REPLAYTV DISC - DO YOU WANT TO PROCEDE.
I stopped and exited here.
I'm probably missing something basic or being over paranoid about the "PROCEED" meesage.
Thanks so much.
Pete
1stTry:
0) SAMSUNG SV1204H - (120 GB) - NOT a ReplayTV Disk
1) ST360021A - (60 GB) - May be PC Disk
2) ST360021A - (60 GB) - May be PC Disk
Source: Select a drive from the list and click 'Set'
Target: 0) SAMSUNG SV1204H - ( 120GB ) - NOT a ReplayTV Disk
RTVPatch version 2.4, built on Jan 19 2003, 12:54:57
\\\\.\\PhysicalDrive0 (SAMSUNG SV1204H) : Detected size = 234493056 sectors
\\\\.\\PhysicalDrive1 (ST360021A) : Detected size = 117231408 sectors
\\\\.\\PhysicalDrive2 (ST360021A) : Detected size = 117231408 sectors
\\\\.\\PhysicalDrive3 : DFP_GET_VERSION failed (not a hard drive?)
\\\\.\\PhysicalDrive3 (Unknown) : Using binary search drive size detection
\\\\.\\PhysicalDrive3 (Unknown) : There appears to be a seek overflow problem on this drive, interesting!
\\\\.\\PhysicalDrive3 (Unknown) : Detected size = 267386880 sectors
\\\\.\\PhysicalDrive3 (Unknown) : Unable to read partition table
Copy from source 'C:\\Documents and Settings\\Pete Brennan\\My Documents\\Programs\\Showstopper&replay30xximage3.02.zip' at offset 0
Copy to destination '\\\\.\\PhysicalDrive0' at offset 0
Copying 76509 blocks (37MB)
*** Resetting MPEG partition
Partition 1 size is 1336123723 (0x4fa3a14b) blocks.
Partition 2 starts at sector -1128182172 (0xbcc14e64)
*** ERROR: Partition 2 does not start immediately after partition 1
*** Restore complete
2nd Try:
Copy from source 'C:\\Documents and Settings\\Pete Brennan\\My Documents\\Programs\\RTVPatch.img' at offset 0
Copying 2880 blocks (1MB)
Partition 1 size is 0 (0x0) blocks.
Partition 2 starts at sector 0 (0x0)
Thanks so much.
Pete
1stTry:
2nd Try:
