Status
Not open for further replies.
1 - 8 of 8 Posts
I am using a Radeon 8500 with CAT 3.2 drivers, WIN 2000 hooked up to a HS10 via DVI.
I have followed the instructions on two different sites and I am still having problems moving the combination to 1366 x 768 resolution...
I input all the information to the add resolution screen and when I press the add resolution it reboots the computer. Nothing is saved and the computer reboots on its own.
Does anyone know what I am doing wrong?
Steve
The resolution will not appear on the user installed list
after you hit add resolution until it re-boots. Is it on the list after re-booting?
Freak!
Swatkins,
I was having a problem along those same lines with my 9000 Pro and CAT 3.2. What I noticed is that just before the reboot I'd have a BSOD that would show up on my TV but not my monitor. I ended up reloading the drivers and the ATI control panel (I think that's what it's called) from the CD and it works fine now. I haven't done any serious testing to see what my problem was, but I think it may have been because I loaded the CAT 3.2 on a fresh Win2k install and didn't have the control panel installed.
Did you install the drivers/control panel off your CD then upgrdade to 3.2 or did you install 3.2 from scratch?
Discussion Starter · #4 ·
Freak!
No its not on the list,,,, I don't think it is saving anything because when it restarts windows I am always asked to restore my active desktop, and that indicates a unexpected shutdown....
Micah
I have reinstalled all the drivers and control panel after I installed windows and I have reinstalled them twice.....
Discussion Starter · #5 ·
Here are the settings that have been found to work with the HS10.
Here are the details for Powerstrip settings for your HTPC to work with the HS10.
• Timing parameters: 1366x768=1366,65,142,207,768,1,3,21,79046,39
• Horiz res: 1366
• Vert res: 768
• Horiz refresh: 45 Khz
• Vert refresh: 56 Hz (most important value to obtain WXGA, needs to be somewhere between 55.9 and 56.9 Hz)
• H-sync: negative
• V-sync: negative
When I look at the Custom Resolution screen in powerstrip I see these fields.
New Resolution
****** Active Pixels *********
Horizontal Vertical
***** Refresh Rate ******
***** Front Porch ******
***** Sync Width ******
***** Back Porch ******
* Positive Polarity * Positive
* Composite sync
Pixel Clock
Aspect Ratio
* ANY * 4:3 * 5:4 * 16:9 *16:10
* Lock Total Geomerty
ADD NEW RESOLUTION
Could anyone help me with the values to add in the * spaces? What I have added looks like this.
New Resolution
1366 Active Pixels 768
Horizontal Vertical
45 Refresh Rate 56
65 Front Porch 1
142 Sync Width 3
207 Back Porch 21
(Unchecked)Positive Polarity (Unchecked) Positive
* Composite sync
Pixel Clock
79.002
Aspect Ratio
* ANY * 4:3 * 5:4 (Checked) 16:9 *16:10
* Lock Total Geometry
ADD NEW RESOLUTION
When I hit the ADD NEW RESOLUTION button the computer immediately reboots, and nothing is saved..
Any Ideas?
If the resolution doesn't appear on the list after reboot - it usually means the your video drivers have not accepted
the new resolution.
Are you sure your card and drivers can handle the resolution that you are asking?
Discussion Starter · #7 ·
the new resolution.
I assume it can, I am 99% sure others have made it work.... Radeon 8500 with cat 3.2 drivers.....
What I think is happening is that nothing is being saved to the list because the program is rebooting the computer, not after it is saved and I am asked to reboot but something is killing the computer when I press the add new resolution button. What that could be, I have no idea :(
Discussion Starter · #8 ·
And the problem was.....
Heck if I know :)
I found that Powerstrip has a board and I asked for help there. It was very responsive help and very fast. They suggested different settings and when they did not work they suggested that I download the "very latest" program which worked like a charm!
Keep in mind that I had just downloaded the program two days before :) So I suspect they tried out my problem and released a version to take care of the bug that was making me pull my hair out :)
Whatever they did it works now and I will soon send them a check!
Thanks guys for all the help
1 - 8 of 8 Posts
Status
