I just got a Mitsubishi 62725 DLP and I use DirecTV HD TIVO HR10-250 for my programming. The HD TIVO is connected to the TV via HDMI cable.
Since there is only one HDMI input on my set I am forced to use component connection from the DVD to the TV. (I watch much more Satellite than DVD so I would rather use the HDMI on the SAT)
My question - I have seen rave reviews for the Panny DVD-XP30 (under $300) - will this fit the bill for me???
I want something upconverts that gives me a 720p picture since that is my TV's native resolution.
Also, would the Toshiba SD-3960 (under $75) work?
I just cant justify buying a crazy Denon DVD-3910 for over a grand! Especially since I will be renting about 2-3 movies a month... Keep in mind that I have no choice but to use the analog component cables...
Any other DVD recommendations?
Thanks in advance for the use of your knowledge!
