1 - 3 of 3 Posts
Burnt up my dad's Ox Pro Series Projector, which I believe was immensely cheap. Used it for Blu Ray and gaming and occasionally television. We can't seem to find a replacement bulb anywhere on the internet. It cost us about $400, but that was back in 2010.
I'm new to all this. But I'm looking for a projector than can cover an 11 foot screen, with a price range ending at $500.
Had my eye on this:
http://www.ebay.com/itm/Epson-MegaP...35?pt=US_Video_Projectors&hash=item2ecaf3f707
Also, what's up with these cheap ones? Why are they so cheap? This ohttp://www.ebay.com/itm/Mini-HD-1080P-LED-Multimedia-Projector-Home-Cinema-Theater-PC-AV-TV-USB-VGA-HDMI-/281278822149?pt=US_Video_Projectors&hash=item417d863705ne for example:
Sorry if ask to many questions. I'm trying to understand as much as possible. And thank you in advance!
Those cheap projectors are just toys and should be treated as such. For Blu Ray I would save up another $200 and get a 1080p BenQ 1070. If you are absolutely stuck with that budget then the 720p Optoma hd180 would be a good choice. Avoid your business data projectors and anything you can't find solid reviews on from other sources than the seller.
The already mentioned 180 along with the Acer 5380 are the best looking around $500, but for $200 more, getting that w1070 will give you arguably the best projector under $1900! It also has very long lasting lamp-life which is never a bad thing.
The cheap LCD and epsons will have much worse measured (actually measured) contrast.
The cheapest LED models will be putting out a measured (truly measured) brightness around 20-150lumens which will make for a dim screen. There are some $450-500 LED DLPs putting out around 400lumens, but only a working gamma control (easy if you're playing from a PC/laptop) will make that low brightness good for dark scenes at that size.
1 - 3 of 3 Posts
