1 - 4 of 4 Posts
Discussion Starter #1
I need to replace a tweeter on a DCM Time Frame V 6.0. Anyone know what brand\type they used. It is a 3/4" 8 ohm as best I can tell. Pictures coming.
Since that is such an old speaker, doubtful you will be able to find an exact replacement. You'll want to change the tweeters on both speakers you have. Unfortunately, whatever you get will probably not be an exact match. It may sound worse. It may sound better.
I'd check Parts Express and Madisound for tweeters.
1 - 4 of 4 Posts
