Well guys, i need some advice, this will be my first serious build, and then a PC for the office to follow.
I will list the components that will go into this machine, but i need advice as to what case would work the best, as well as fans, i would like silence, but i dont want to sacrifice function for form, you know what i mean....
Tell if you think anything is overkill or w/e.
the funds are mostly a graduation gift from my pops, its gonna be like 5000 total, but id like to save a good bit for a big screen monitor and a sound system for the car.
here it goes.
Processor, PSU, and MOBO.
- Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail
- EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
- Thermaltake toughpower W0117RU ATX12V / EPS12V 750W Power Supply - Retail
Drives/Optical
- LITE-ON 20X DVD±R Burner with 12X DVD-RAM write and LightScribe Technology Black IDE Model LH-20A1H-186 - Retail
- ASUS Black SATA DVD-ROM Drive Model DVD-E616A3T - Retail
- Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
- Seagate Barracuda 7200.9 ST3500641AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
- LINKSKEY LKA-CR15BW 52-in-1 USB 2.0 Internal 3.5" USB Card Reader - Retail
- XBOX 360 HD DVD Drive
Memory and Peripherals
- BFG Tech BFGR88768GTXE GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
- Creative Sound Blaster X-Fi Elite 7.1 Channels PCI Interface Sound Card - Retail
- Kingston HyperX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 900(PC2 7200) Dual Channel Kit Desktop Memory Model KHX7200D2K2/2G - Retail
Please let me know if im missing anything crucial....
I was thinking about the Thermaltake Tenor case, because i love the way it looks, but im not sure that everything will fit, i will be adding another 8800 gtx in about a year or two, thats why the psu is 750, but if you all think different let me know.
Also, i dont know which cpu cooler to get, because that really depends on the size of the case. Suggestions for silent fans would be nice also.
here it goes.
Drives/Optical
