1 - 5 of 5 Posts
I have a Yamaha RX-V475, but no speakers yet, I'm considering this options:
Q Acoustics 2000i
- 2xWHARFEDALE Diamond 10.2
- WHARFEDALE Diamond 10 CS
- 2xWHARFEDALE Diamond 10 SR
- WHARFEDALE SW150
Polk TSX 330
Polk TSX 110
Polk TSX 150c
Polk PSW 110
WHARFEDALE DX-1 HCP (not sure if these ones are supported by the yamaha as they have 4 ohm impedance)
I have been for a week trying to decide, but I haven't decided yet... Any advice? Anyone has listened to any of them?
Discussion Starter · #2 ·
I'm thinking I'm going to choose the polks, anyone has listened to them? I have been trying to find reviews, but no luck this far...
Originally Posted by XxOsurfer3xX  /t/1503887/need-advice-choosing-5-1-speakers#post_24039110
The TSX line, to me, sounds a little warmer than some of the other Polk lines. I went with the RTI line which is one notch above the TSX's but I really liked the way the TSX330 and 550 sounded (didn't care for the 440 as much but it might not have been set up properly when I heard it). Some people will say the TSX is the updated Monitor series, but it is not. These sound very different in my opinion. I have not heard the Wharfedale's but they get great reviews. I think you will probably be fine with either.
fwiw, I'm assuming your from the u.k or other European country with the list you have given. what is a reasonable budget for 5.1 system. how big of a room and how far away from tv do you sit. is this system mainly for tv/movies or will music and gaming be used also
Discussion Starter · #5 ·
Originally Posted by smasher50  /t/1503887/need-advice-choosing-5-1-speakers#post_24039139
Yes, I am European. 400-900 euros but 900 would be pushing it a lot.
70% Movies - 20% gaming - 10% Music
Room is 20 m2. I sit 2m away from my TV.
1 - 5 of 5 Posts
