1 - 2 of 2 Posts
· Registered
I tried searching and found some info but most recommendations were for superior spec'd projectors than needed. My needs are robustness and long hour life. Its a basic SD analog signal in a reasonably dim room. The screens arent anything fancy and are bright white. Everything is already wired and mounts are already installed I just need advice pointing me towards a good unit that is reasonably cheap.
Also anyone have advice on cleaning screens in a restaurant? They get greasy and attract dirt. Cleaning with standard hot water or mild soap makes them streak badly. Thank you.
· Registered
But the problem is not every mount will be suitable for all projectors?
I would recommend you looking at low end business projectors as it seems like you just need a projector for simple purposes, perhaps just background entertainment right? Nothing fancy. There are numerous brands you can look at: Epson, Optoma, NEC, BenQ, Casio, Mitsubishi, etc.
Just to give you a few options to start with:
Optoma TX542 (DLP)
Costs about $680
2800 lumens
3000:1 contrast ratio
29 dB noise level (eco-mode) vs 31 dB normal mode
5000 bulb hours (eco-mode) vs 4000 normal mode
PC less projection
BenQ MX615 (DLP)
Costs about $600
2700 lumens
29 dB noise level (eco-mode) vs 33 dB normal mode
5000 bulb hours (eco-mode) vs 3500 normal mode
PC less projection
Casio XJ-A130 (LED)
Costs about $800
2000 lumens
1800:1 contrast ratio
noise level ????
20,000 bulb hours
Now I haven't seen the Casio in action but I threw it in because it uses LED and has long bulb hours, but the contrast ratio is much lower than the other 2 and is the least brightest out of the 3 so it may be something you should consider. I think the BenQ and the Optoma would be great choices either way, but if bulb hours is your concern, perhaps the Casio. Either way, try to have a look at these before buying them to see which one suits you better
1 - 2 of 2 Posts
