1 - 6 of 6 Posts
Discussion Starter #1
Looking for advice on my speaker setup. Room is roughly 19x14 with 7.5' ceilings. Viewing distance to the AT screen around 12 feet. Looking to do a 7.2.4 setup up.
With the research Ive done Im thinking HT10s for L/C/R and Stonehenge subs (due to the lack of depth behind the AT screen wall (24")).
Because the room is narrow and Im trying to fit 4 seats I would like to do in-wall for rears, surrounds and atmos. These I haven't done much research on.
V10's / V8's can work in wall, IB style
IB = infinite baffle > no box / cab
mounted directly into the wall-tho there maybe need for some spacing required wrt to over all depth of speaker vs, wall depth . .
visit the DIY thread and ask about using these units IB-you won't be the first
and those who have had narrow issues like you found good advice
Discussion Starter #5
will do. Thanks
check this work and these guys . . they know
Volt 10’s as atmos speakers in drop ceiling using Baltic Birch and no enclosure
1 - 6 of 6 Posts
