Before I eventually wound up purchasing my H/K receiver, I did a lot of research between H/K and Denon.
To be honest with you, I did not find much at all to differentiate the two, both getting very good scores on quality, sound, power, etc.
If you are just wanting to buy a receiver for the next year or two to hold you over for your "big" receiver purchase later, than I would go with the cheaper Denon. That said, you can't go wrong either way in my opinion.
Good luck.
Good luck.
