if you have powered speakers then you can run them off the sound card. Some powered speaker sets are getting very good.
Home audio speakers require an amp/pre amp or reciever to work correctly, the reciever can be fed by your sound card of course.
So it depends on your speakers, but I'm going to guess you'll need to use one of your recievers.
There are really on two commercial grade audio solutions out there right now.
The audigy series from creative and the via envy 24.
The better via cards have very similiar sound quality to the audigy, but the audigies have EAX4 and DVDA. Although to get either EAX4 or DVDA you'll need to hook up to your reciever using a 6ch analog in. The via envy has about the same quaility audio but doesn't have some of the frills and costs alot less.
Either one can be hooked up digitally to pass DD and DTS through to the reciever unmolested.
