Need advice on entrance planning
447 Views 4 Replies 3 Participants Last post by  Bobbejaan
2
Hi guys (and gals)
I am meeting with the architect again soon and need your advice on the entrance
to the theater.
In pict A. I have a double-doors entry ( doors marked with red). This should help with sound isolation. My big concern is that I won`t be able to get big boards, 2x4`s , recliners ect through the doors as indicated by the blue arrow.
In pict B I removed the outer door. The path into the theater is "bigger" now.
What do you guys think. Will I be able to get the stuff through in plan A or will 1 door be good enough for sound isolation. All walls in the house are brick and not drywall. Any othe suggestions would be appreciated.
Thanx
Bobbejaan
See less See more
Status
Not open for further replies.
1 - 5 of 5 Posts
Without dimensions on the drawing it is tough to tell. How wide are the doors?
If it were me, I'd go for plan A with 42" doors.
Would it work to put the outer door at an angle?
Sorry, guys. The doors are standard inside doors - inside opening 80cm (32") - standard for S.A. anyway :)
Deane, do you mean something like this?
See less See more
1 - 5 of 5 Posts
Status
