Status
Not open for further replies.
1 - 8 of 8 Posts
Hoping that some of you have gone this route:
Have 9501LC for movies, want a high lumen PJ for daytime TV viewing in light filled room.
What have you folks gone with?
I am thinking about the LT260.
TIA
You probably won't be able to do it... and if you could, you'd probably need something the likes of a 2200L PLV70.
As Jpinto says, a projector probably isn't the answer for a daytime light filled room use. Even though you'll by able to see the picture (using a PLV 70), PQ will be so sub-optimum you probably won't like it.
If you go that route anyway, another less expensive option is the Panasonic 720U which also does 2200 lumens.
Doesn't it also depend in part on the screen size and shape. I mean there is that 10x wide-angle screen and the 20x narrow-angle screen or Vutec's curved 13x gain screen... They are not flat, but they would provide a picture in daylight with even moderate lumens, I'd bet.
mark
PLV70 and one of Vultec's High Gain screens, maybe like the silverstar
James
I have a Boxlight SE20HD (read PLV-70) and I have to agree with HTCrazy. While the picture is definitily watchable during the day when some light control is implemented, it is less than optimal. With fptv, ambient light is a problem. Of course, glare is a problem with just about anything. I am not a fan of rptv for the same reason. I agree, plamsa or direct view is the way to go in this situation.
1 - 8 of 8 Posts
Status
